bellhousing swap problem
Nyteryder
Car: 90 240sx(sr20det), 98 altima(75 shot of n2o) 01 jetta 1.8t
I just did the sr to ka bellhousing swap and it seemed simple but after we got the transmission put back in and fill with transmission fluid i noticed after I drove for a few minutes I had a big leak, it was almost a steady stream, when I fill it up within a couple hours I am empty. All the bolts are tight and the fluid is coming out of that little hole by the bottom bolt of the housing, is there any thing that could have shifted while putting the transmission back on or is there some gasket that I did not see that need replacement, any help would be appreciated.
s13sr20chris
its gear oil thats leaking right? ok, you need to have used rtv when you put it back together. did you do that?
