Bellhousing and upper oil pan
streetbikestunta420
Car: nissan 240sx/red top sr20det
Okay what's up people I just had a quick question so I'm removing my upper oil pan and it seems to have 2 bolts attaching it 2 the bellhousing, when I remove these 2 bolts will any trannyfluid leak, I doubt it but just though i'd ask cuz Ive split enough **** on it and just though id try. 2 keep it clean during this haha
jr_ss
Car: 95' S14
The upper oil pan is only bolted to it, there is no oil transfer between the two. Trans oil is different from engine oil...
CoupedUp
Car: 1993 Coupe
I think he is thinking that there is oil in the Bell Housing.
The bell housing(the part that attaches to the engine) is an empty space for the Clutch Slave, Fork Assy, Flywheel, Clutch and Input shaft for the transmission. The oil is kept even farther behind that behind a seal on the input shaft.
streetbikestunta420
yea cuz im tring to take off my upper oil pan but i cant but i notice that iit looks like its bolted to the transmission bell housing,,is it bolted on or iam i just tripping?
supreamS14
Car: 96 240sx S13-blacktop Sr20deT
The upper pan is bolted to the rear seal bracket as-well.
streetbikestunta420
supreamS14 wrote:The upper pan is bolted to the rear seal bracket as-well.
damn i didnt know that..where is it located by the bellhousing? and its just a bracket? how dose it look?... i took off all bolts (exept rear seal bracket) and i lifted engine but i had no luck removing U.O.P it was styuck on there good..hopefully it is just the bracket holding it on.. aby1 know of a good way of getting silicon unstcuk or iam i just gonna have to uses some elbow grease?
supreamS14
The UOP has extra bolt holes near the rear that are threaded. If you screw a bolt in on both sides and tighten them a few turns at a time, it will push the UOP away from the block. I think there is a small access plate on the UOP that you might be able to get at the 2 10mm nuts that bolt the rear main seal bracket to the UOP.
streetbikestunta420
supreamS14 wrote:The UOP has extra bolt holes near the rear that are threaded. If you screw a bolt in on both sides and tighten them a few turns at a time, it will push the UOP away from the block. I think there is a small access plate on the UOP that you might be able to get at the 2 10mm nuts that bolt the rear main seal bracket to the UOP.
kool and where is the main seal bracket? top/ side/bottom of uop?
supreamS14
it holds the rear main seal that seals around the crankshaft. If you ever pulled your transmission you would know what it looks like.
Do you have a FSM? You should download one!
streetbikestunta420
So wait I'm supposed to take off the transmission?
supreamS14 wrote:it holds the rear main seal that seals around the crankshaft. If you ever pulled your transmission you would know what it looks like.
supreamS14
I always pull the motor and transmission. Get the fsm! I think you can do it the way you wanted.
Sileighty_85
Car: 1991 180SX
You dont have to pull the transmission to unbolt the upper pan just the transmission bolts that bolt too it. (there is not fuild in the bell housing) although its a ***** to pop off, the RTV on it seals really good so you need to find a flat blade and breaks the RTV seal all around to make it easier.
When you pull the pan with the rear seal plate on still make sure you pull it off straight to avoid snapping the studs for it
Dont forget about the alternator Bracket also
streetbikestunta420
Sweet thanx for the help umma try to get it off tommorow morning but just to be clear I don't have to take the real seal bracket to take off the uop?
Sileighty_85
Car: 1991 180SX
Right you dont have remove the rear oil seal to pull off the UOP
but it will be easier if you pull the transmission though for for the oil seal boltscuz there kinda tucked in there
They are 2X 10mm nuts just to let ya know
streetbikestunta420
Where are the oil seal bolts at? Do I gotta remove them before or after taking off the uop?cuz ibelieve I got allthebolts connecting it off I just gotta pry that **** off but I've never taken off anupper oil pan, **** I've never even heard of one ha
Sileighty_85
Car: 1991 180SX
In my pic i posted do you see the two studs sticking up?Those are them
There is a gold looking acess plate in the rear that should let you able to remove the the two nuts for it
streetbikestunta420
Sileighty_85 wrote:In my pic i posted do you see the two studs
ok Kool I got the 2 nuts off the rear but this damn rtv is holding it on good I can't seem to pry it off
Modified by streetbikestunta420 at 1:48 PM 1/20/2009
Sileighty_85
Car: 1991 180SX
streetbikestunta420
Yea I just got the back end unstuck now I just gotta work the frontBy the way thank u for all the help sileighty_85 I really approviate it!
