quick question.
i have a ca20 e injected motor can i bolt on the ca20 e carburated gearbox? eg bell housing measurements the same.. gearbox has been on car but since my original clutch went i have been having issues with the new clutches. everything is new. clutch kit, slave cyl, master cyl, went together with no problem. the only difference i found was thrust bearing thickness, so i kept the efi clutch set up and disposed of carbi bearing.
please help i'm sick of popping clutches
