Ok so I have an s14 with an RB20det that i'm currently doing a rebuild on. My Goal is 450-500whp...
My build setup is going to be as follows...
CP Pistons 78mm 8.5:1 compression ratioARP Head studs, main studs, and exhaust manifold studsCometic multi layer head gasketOem gasket/ seal kitForged connecting rods and crank collar from spool imports AustrailiaACL main and rod bearingsGreddy oil pumpNew oem oil pump and timing kit
This is my first time building a Nissan engine. I'm an Audi technician and working at a new car dealership there's one thing I never had to deal with that im dealing with on my 240 and that's RUST... On my Rb20 This gear...
Is rusted on Ive gotta get if off to install my crank collar, oil pump, and main bearings.
I searched this sites for threads related to this before I posted and I found this...
zerothread/250400
In this thread some of the things they mention would get the lower timing gear off but could damage it...
My question is for people who have built rb engines before. What did you do to remove this gear WITHOUT damaging it.
My snap on guy has a tool similar to this...
I was thinking about trying this, with some pb blaster but i'd have to drill and tap one hole on each side of the gear in order to get this tool to attatch to the gear but before I did that I wanted to get some input or recommendations. Any help would be appreciated
Heres some more pics just for the hell of it...Sorry 56k people
