sooner4x4 »
https://forums.nicoclub.com/sooner4x4-u71453.html
Thu Apr 21, 2011 5:34 pm
You don't hear about a lot of problems with them. My 2007 S sedan has been reliable (45,000 miles). The only issue was the steering column assembly that had to be replaced under warranty. A few Versas have had this problem as reported on this forum, the symptom to look for is a clunking sound when making a slow sharp right turn like in a parking lot. Lost the wheel covers a couple of years ago, and replaced with some inexpensive ones from Pep Boys that have stayed on and look no worse than the Nissan ones.
The fuel filler door release has had a few problems when the cable becomes unattached at the lever under the dash, on my car.
Basic maintenace is easy if you are a do-it-yourselfer. Air filters (engine and cabin) are very easy to replace. Oil changes are pretty easy. Simple drain and fill on transmission (auto 4).
Gas mileage on mine has been disappointing (around 24 mpg). If you plan on doing a lot of higher speed highway cruising, the gearing isn't so great, revs high at highway speed with the automatic 4-speed. I view the Versa as more of an around town kind of car. My daughter is the principal driver of the V and she loves it.
