? befor i do my swap please help
dukeS13
Car: White 93 240sx with s13 frontend and a redtop sr20det
Ok I got a 93 240sx coupe an a s13 redtop sr20det frontclip the only problem is that the frontclip an my car has been sitting for like 2 years what problems should I look for because its been sitting for so long please help me if there is anything I should look for the whole frontclip is in great shape everything looks new. Also my car is automatic an I'm switching to 5speed with the swap
compactfean
Car: 89 240sx s13 sr gt3071r 23psi
B14 sentra ser sr20de-t 7psi
daily
Just your normal stuff. Id pull intake and exhaust manifolds and replace ALL exhaust, intake, and misc gaskets and rubber hoses (including the coolant rail under the intake mani) other than that, before you start the car unplug the cas and crank it to get some oil flowing through the motor, then plug it back in and start it.
dukeS13
Thanks for the info I need as much help as I can if there is anybody that lives in hammonton,NJ and don't mind helping someone doing a sr20det swap hit me up
