Beeping alarm going off in my M35
kpdoughboy
Not sure what it is but randomly I will hear a beeping alarm go off in the car. I think it has to do with traction control? Not sure. Can anyone shed some light on this.
Thanks
svard75
Car: 06 M35x
What exactly are you doing when the beeping is going off. For example if I open my passenger door while the engine is running and I am in D it beeps kinda like a warning. If the car is running and I keep my keyfob in my pocket and exit the vehicle it beeps several times and a No Key message appears in the trip area screen. I'm pretty new to this car so it appears normal to me.
Edit: Sorry forgot to add when my keyfob battery was getting low I heard a random beep as well but that disappears once you replace the batter.
CHEERS!
EniGmA1987
Car: '06 Infiniti M35 Sport
lol it is probably the lane departure warning system
kpdoughboy
I can't really pinpoint when it happens but it happens when I'm driving. At first I thought it was when I accelerated too fast but then it would go off when i change lanes too and the lane departure feature is turned off. So I think it's random. Maybe its the batteryfor the key then. hmmm....
haab4u
Car: 2K6 Black Obsidian M45 on FX50 21's
kpdoughboy wrote:I can't really pinpoint when it happens but it happens when I'm driving. At first I thought it was when I accelerated too fast but then it would go off when i change lanes too and the lane departure feature is turned off. So I think it's random. Maybe its the batteryfor the key then. hmmm....
It's your LDW system (Lane Departure Warning) System. Read your manual, it'll tell you all about it.
Stan_izzle
Car: Ivory Pearl 2006 M35
Journey PKG - Sport
Technology PKG
I'd have to agree with the others. It does sound like the Lane Departure System. Look down at your dash when you hear it. If it is the LDS you will see the icon flash.
SteveTheTech
Car: 15 Nissan Sentra SR
12 Infiniti G37x Coupe
-Formerly-
05 Mazda 6 L3 Sport
95 Infiniti J30
94 Nissan D22
It really depends on what exact type of beep you are hearing. After thinking about it for a little while there are a ton of things that could cause a beep. You need to try to pinpoint what type of beep it is from. The key related beeps are different from anything that the AV or LDW system will emit.
The TPM system may be alerting you. Do you have your tires adequately inflated and programmed?
rsg123
Car: 2006 M45 Sport
This reminds me of when my brother took my newly bought M out for a spin. He called and sound worried. "I think there is something wrong with your car...the traction control light and warning sounds keep going off". I laughed and told him to start using his turn signals.
InfinitiMe
Car: 06 M35x Blue/Wheat
kpdoughboy wrote:Not sure what it is but randomly I will hear a beeping alarm go off in the car. I think it has to do with traction control? Not sure. Can anyone shed some light on this.
Thanks
if it's a long, sustained beep it may be the low tire pressure warning. Check your tire pressure
jcarpent16
Car: 2006 Infiniti M35 Sport
Thanks
Yep, if there is a (!) icon check the tire pressure readings under info. Keep em above 32-34
