Some time ago, I got with deviousKA about a not-so-average tuning setup for my upcoming build, involving launch control / anti-lag / flatshifting features.
Obviously, the build is progressing just fine, as I've shown in the "Engine p0rn" thread.
Well, here's the tuning end.
It's a daughterboard supplied and base tuned by deviousKA. The board is unique, in that it offers multiple file storage and onboard remote switching.
The board can store up to 4 individual files (tune maps). We put our heads together and deviousKA came up with a plan to use the files in pairs.
The first set is Base tune 1, Switch tune 1 and the second set is Base tune 2, Switch tune 2.
Both base tunes are identical. They're tuned for 370's and Z32 MAF on a T3/T04E around 8psi (I think there's room for more there...)
However, Switch tunes 1 and 2 are different from the Base tunes and from each other. Switch tune 1 has a rev limit of 4,000rpm and 5* timing retard. Switch tune 2 has a rev limit of 4,000rpm and 10* timing retard.
These tunes are applied when the remote switch circuit is complete. The switch is mounted in a position that allows it to be actuated by the clutch pedal. When the clutch pedal travels about 15mm, the switch is "clicked" and the Switch tune is activated (which tune is used is determined by the dip switches on the board). Once the clutch pedal is released and the switch circuit is interrupted, the ECU returns to the Base tune.
The purpose of the Switch tune is for launch control and flat-shifting (not letting off the throttle between gears). The timing retard helps keep the turbo spooling between gears, and is also to create boost while in the staging lane with the clutch in @ WOT. I'll need to raise the rev limiter on the switch tunes to around 5,000rpm, as 4,000rpm is just too low to make any boost. It does spool the turbo (I can hear it just fine), but not enough to make positive pressure. The boost threshold in 3rd gear is around 3700rpm, so 4,000rpm in nuetral just won't do it.
My opinion:
This setup absolutely ROCKS! The tune was nearly dead on. I'm showing just a tad bit rich under boost, but that might change with the new engine, where all my intake charge doesn't blow out the valve cover from worn out rings. Remember, I'm testing this setup on the old tired 200k mile KA-T. That way, if I blow it, who cares?
The flat-shift/launch control is excellent. I haven't fully launched the car yet, but I've played around a little and it's pretty fun. Also, shifting gears without lifting the throttle, in conjunction with the timing retard, makes for some FAST turbo spool recovery.
I'd recommend this setup to ANYONE who wants a multi-functional board, but can't really justify springing for a $1,000+ standalone. I can't verify the board's availability or the price at which it will be offered in the future, but I can tell you that it's certainly worth waiting for one. Just contact deviousKA (
www.hybridka.com) and he can give you details as to the availability and price.
One thing to keep in mind, this board will require a chip burner and you cannot do on-the-fly tuning. You'll need to know how to work a set of maps, accurately determine the cell in which the ECU is operating, etc.
I'll do more testing/tuning with the launch control setup later. Once it's dialed in, I'll post results. Tomorrow I'll get some photos of the board itself up.
