been off of nico for almost 6 months thought id stop in and do a little update on my coupe.
re did alot with the motor (headgasket/intake manifold gasket, paint ect), new wheels, brakes, suspension, got the dash covered, also have some 680cc's and an 8 blade holset hx-35w im hoping to have in my the end of summer!
also i got a small sample of some LV4 skyline midnight purple(sprayed the lower taillight garnish) cant wait to get the whole car purple!
here she is...let me know what you think!...i know i need to lower the back a little bit more lol
ENJOY!
Engine
2.5l turbocharged Rb25det, TopHat motor/trans mounts, Touge factory steel braided turbo lines w/ restrictor, Nissan N1 oil pump, Godspeed front mount intercooler, intake manifold, radiator, hoses, 2 12” electric fans, CX 80mm throttle body, cometic intake manifold gasket, Walbro fuell pump, z32 oil/fuel filter, full gasket overhaul, custom 3” exhaust, custom 3” intake, rb26 oil filter housing, NGK iridium plugs
Drivetrain
Rb25det 5 speed, driveshaft shop 1000hp steel driveshaft, ACT 6 puck HD clutch, Nissan z32 r200v differential
Engine management
Unwired S1 S-AFC
Footwork/chassis
Cusco Front 32way coilovers, megan racing street rear coilovers, Godspeed rear upper control arms, rear sway bar, tien tension rods, energy suspension control arm bushings/steering rack bushings
Brakes
300zx 30mm front calipers, drilled/slotted rotors, steel braided conversion lines, 03 altima drilled/slotted rear rotors, z31 rear caliper bracket, centric pads
Wheels/tires
Front and rear Ichiba 5 lug hubs, Front: enkei RPF-1 17x9(+22, 3mm spacer) dunlop 225/45/17 , Rear: enkei RPF-1 17x10(+18) falken 245/40/17
FR camber: -1.2
RR camber: -2.4
Exterior
Complete B*Magic body kit, OEM metal s13 silvia hood/fenders, Nissan triple projector silvia headlights/corners, custom molded body line, DuPont sovereign blue paint, custom pulled fenders
Interior
Custom fan switch, coverlay dash cover, prosport 52mm oil pressure/boost gauges, autometer wide band AFR gauge, 2+ layers of sound deadening, undercoated trunk, battery relocation, custom cup holder, loud a** horn
