Been MIA for a bit but have some rb20 questions.
bmxer300zx
Car: 1993 300zx dd
1992 toyota cressida rb20det swapped
Well i haven't been on nico for a while but, i am at a spot in my project where i could use some rb specific help and figure this is the best place.
I currently drive a rb20det swapped cressida this is my build if anyone is intrested
http://forums.240sxone.com/showthread.php?t=23946
I am redoing the car and alota wiring, i also bought a forward facing plenum and was wondering about deleting the iacv and cold start valve. I did a lil research but no real solid advice. I know i have to adjust the throttle and reset the tps but is there anything else that needs to be done? My only reason for this is to clean ip my engine bay and not deal with the hassle of the air plumbing . Anyways hope someone can chime in and help. Thanks and sorry for crappy engrish lol
Carl H
should be just fine as long as wiring is correct...may take a few tries to get it started when its really cold but it will run.
bmxer300zx
Car: 1993 300zx dd
Alright thanks man. I figured thats all there was just most people on forums that i can across were short and didnt give much info aside from adjusting the tps for the slightly open throttle. As far as wiring its just inplug old sensors? If so im just gona pull em back outa the bay then but leave option to reinstall them if i want/need to. Car should run fine, i first strated it almost two years ago and after i sold my z32 its been my daily for a year now. But thanks for the input just wanted to make sure.
