steve_c »
https://forums.nicoclub.com/steve-c-u163301.html
Thu May 26, 2016 10:15 am
Sounds like your transmission clutch packs are wiped out.
I wish you had gotten a sample of the drained transmission fluid so it could have been analyzed,
but from how you describe the conditions I fear the worst.
That little bit of get up and go when cold is because the clutch packs are down to metal,
being pressed together by the cool transmission fluid when cold. As the metal plates get hot from the friction
this produces, and the oil heats up, you start to slip again. No more clutch material left on the plates to keep it all locked up tight!
I am sure if you removed the transmission pan you would find lots of clutch material in it.
Of course I could be wrong, it all has to be checked out, but this is just my opinion from how you describe things.
How many miles do you have on the vehicle?
Just a thought, double check the transmission fluid to be sure it was not overfilled/underfilled.
You can check this via the charge tube behind the engine. The tube cap should double as a dipstick.
