float_6969 »
https://forums.nicoclub.com/float-6969-u780.html
Sun Feb 12, 2012 8:36 am
I have something similar, but it's built into my standalone.
It's like anything else, if you mess around, and are showing off, it's usually gonna bite you in the azz.
If you tune it to do it's job, which is to build boost at a standstill, and tune it only for that, it's fine. The problem is that when you do that, you don't get the insanely loud bangs, and fire out of the exhaust. It just sounds like you've got a weak ignition system and it's missing out. This doesn't cause much harm to the engine as long as you're only doing it long enough to get boost built and then get off the line. It DOES put a lot of heat into the exhaust and exhaust valves, but if tuned right, not much more than it would see in normal use.
The problem is that a lot of ppl who buy them, do it for the "ricer effect". That's when you blow motors. IDK much about the Bee R limiter, but as long as the RPM limit and amount of ignition retard are adjustable, you should be able to set it up so it doesn't harm your engine.
Set the RPM limit for what you want your launch RPM to be (most CA's need at least 3K+ rpm to launch well and not bog). Don't go any higher in the revs than you need to. The more revs you run, the harder to keep wheel spin down, and the more likely you'll break something at launch. Then you start retarding the timing until you get the engine to build enough boost that the engine doesn't bog on launch, but not so much boost that it spins either. Also be aware that the more ignition retard you put in it, the more unstable the boost will be. If it seems like the boost gauge is all over the place (It'll normally waver some), then drop the retard back, and increase the rev limit a little.
