bee R rev limiter
koUki20
Car: 89' Nissan 240sx
would anyone happen to know exactly how to install a bee R rev limter? im not shure if i connected it right. for some reason, the car wouldnt turn on and the bee R sytem wouldnt hav power wen i hav da ground connected. wen i hav the ground off, the car starts fine and the bee R system gets power, but it doesnt seem to work. can anyone help? basically, da car wouldnt start with da ground on, i was wondering y dat is? thanks
s14_240sx
Car: 96 240sx Zenki
try checking you ground for the bee R rev limiter. Make sure the contact point for the ground is not painted, u sand paper and sand it down. This sounds exactly like when i was trying to install my sub. i used a screw driver and scrached the paint of and connected it, but when ever i would connect the ground the amp would turn off. So i sanded it down real nice so the metal was shining and it started working.
koUki20
ill try dat, thanks.
