Bee*R Rev Limiter Problems! Need Help ASAP!
Red*To*Rip
Car: 90' S13
So i bought a Bee*R Rev Limiter on Tuesday and we have encountered some problems.When we looked at the wiring it didnt make any sense.We were missing the yellow wire.Pictures are posted on NECC.http://www.n-e-c-c.com/forum/viewtopic.php?t=9993So the guy i bought it from told us the red and white is the yellow wire. So when we tried to install it everything was going good, the illumination light came on, then we set the rev1 limiter to 2500rpm, now the problem is the revs wouldn't stop.Does anyone no why that is?Has anyone installed one before?
THE ENGINE IS A STOCK KA24E.
Any help would be appreciated!
LayNLow240
Car: 92 240 coupe
Red*To*Rip wrote:So i bought a Bee*R Rev Limiter on Tuesday and we have encountered some problems.When we looked at the wiring it didnt make any sense.We were missing the yellow wire.Pictures are posted on NECC.http://www.n-e-c-c.com/forum/viewtopic.php?t=9993So the guy i bought it from told us the red and white is the yellow wire. So when we tried to install it everything was going good, the illumination light came on, then we set the rev1 limiter to 2500rpm, now the problem is the revs wouldn't stop.Does anyone no why that is?Has anyone installed one before?
here, read this.http://www.driftworks.com/reso....htmlmake sure you cut the right wire for 4cyl/6cyl/rotary
