hey guys how are you all doing......??
I ordered bee r rev limiter and installed it two days ago. Everything is hooked up perfectly as instructed by one of the members here in the forums he posted a video in YouTube and had the ecu diagram.
The Problem is everything works but the ignition does not cut, so the red light work in the right rpm but it doesn't cut. I tried to do the wires again and again but the same thing happens. I really need help with this problem.
