Team503 wrote:I think that wasting the money that an anti-lag system (if there truly is such a thing for streetable cars) would probably cost is a bit asinine on a street car - the hundreth or thousandth of a second it would save you on a lap is useless on the street.
Better put that money to use on tuning your setup. If you build a setup that is well matched for street use (proper impeller/compressor size ratio, exhaust backpressure, flow, etc), then you would have little or no need for such a system.
Again, if you want the flames, run boost, run rich, and run a straight through exhaust. You'll have all the flames you want.
An often unmentioned downside is the huge amount of carbon buildup on your tip (forget ever seeing it shiny again without some type of Simple Green style treatment), your bumper, and where it begins to MELT your bumper.
ya, all you said make sense, u spend thousand and thousand of $$$ on bigger turbo, theory this and that but we must not forget the "brain" the coordinate the work of your spending together. then one would waste all the $$ he spend on these expensive performance parts yet neglect fuel and timing. after all bigger turbo would end up , like you say "would probably cost is a bit asinine on a street car - the hundreth or thousandth of a second it would save you on a lap is useless on the street."
Hugh amount of carbon build up??? does any one who modify their car resulted in a nice shiny exhaust tip??? or do u think just because it's an anti lag system , the car will be running very rich constantly? I doubt so.
anyway, it's his spare car he's toying with and it's his car, it does gives us soem thing to talk about and the possibilities.
street car i meant that it can still drive together with other cars on the road and able to handle a corner not like a drag car.
