bee 8R rev limiter install question
blazinrola80
so i tryed looking up a instal clicked on a few links.. but they have been deleted.. try mostly every like that google gave me.. none of them really worked.. so now i come to you see if you can shine some light.. harness is 93 s13 motor sr20 R/T power fc ecu..
5 wires coming out of B/R harness
red power black groundwhite trigger swtichgreen??? what pinyellow what pin???
can any one help me with what pin and a pin lay out diagram
thanks
3 wires on one side grey white brown witch do i cut for 4 cylinder?
btw this is for a drag car application..
blazinrola80
bump help pls..
blazinrola80
Red - pin 38 ECCS PowerBlack- pin 39 ECCS groundGreen-pin 31 CAS 1 Deg Yellow- pin 22 CAS 180 Deg
found this but i dont kno if its correct... also found a pinout for the 180 sx ecu.. ps13
Modified by blazinrola80 at 10:10 PM 10/3/2009
blazinrola80
ok installed thanks to no one.... i hope this forum is a lil more help full
