vipers weigh 32oolbs and the 24o's weigh about 28oo for an s14, however, look at the tire size and torque of the viper, N/A power is totally different from TURBO powerIWannaS15 wrote:WD,A 2002 Viper with 460hp (crank) can run mid 12's, and the 240sx has to weigh less than a Viper GTS. So a S14 with similar power (400whp) has gotta be able to match the Viper at least. Are you saying that on the street, a Viper would have the advantage because of its awesome torque curve??Anyway I guess 320whp is a little low for low-mid 12's.
Thanks for the replyJay
IWannaS15 wrote:...As for the cars you listed, a S14 will be able to run all over them with just a 7 psi kit.Jay
IWannaS15 wrote: ... Why drop in 370cc injectors when a youre gonna want 50lbs a year later...
IWannaS15 wrote:Honestly WD, I have no first hand knowledge about forced induction. Everything I know (or think I know) comes from what Ive read or seen other people do. This whole process will be a learning experience for me. That's why I wanna work on the KA. So if (or when) I screw up, I can get parts for much less than any swap.I cant justify spending $3k turboing a KA at 7psi and be at the limit of my setup and still lose to a stock C5. From my understanding, the cost difference between a 250whp (7psi) setup and a 300whp setup is relatively small. You just need more fuel and better tuning. The same type of parts are required but obviously tuned for more boost. I'd rather spend the extra money knowing that as I learn more, I can safely raise the boost. (Why drop in 370cc injectors when a youre gonna want 50lbs a year later??) So I would like a system capable of making much more power than I start with to give me room to grow. In the long run, I think this will save me money.I know less than many of yall about building a "high strung" turbo car, but if my goals point me in that direction I'm willing to spend the time and money to learn.
Thanks guysJay
huguetpj wrote:bruinbear... do you have the ROM code for the KA24E or KA24DE? If it's the DE I'll be most interested to take a lookif it's the E just send it over I'll may probably take a look at it while I work on the DE one myself.
It makes sense if you are looking for a plug-n-play solution and can't afford downtime on your car, ie if it's your daily driver. If it's a project car, then it's a different story.IWannaS15 wrote:Bruinbear, I dont think it makes sense to get a JWT ECU for 370cc and have to retune when you upgrade injectors or MAF. Why not pay to setup your system for your highest goal since you can always run less than that.And from what Im learning, I would choose an RB25 for a 12sec car. THe SR just doesnt appeal to me.I would consider a standalone if its more cost effective than the JWT (retune, retune again, retune again) idea. But I would need help in tuning it.
Jay
no, a hacked/piggyback ecu is no where close to the capabilities of standalone. stock ecu's monitor and control the engine a certain way.. standalones do it whatever way you want. i dont think you can reprogram a stock ecu to detect knock and retard timing when needed... or reprogram it to use map sensing.Quote » Cons example: Do you like to restart your Microsoft Windows everyday in your Pentium Processor, when you get "Fatal Error - Illegal operation" blue screen ?gyfer wrote:Hacked ECU will work like Standalone. You are very much reprogram the ECU to accept everything. Instead of changing the values in Standalone, your erase and "hard-program" the ECU the changes you made on your car.
Is like:A normal calculator - come with fixed processor than pre-program <- Stock ECUA TI calculator - come with sophicated processor than you can program the processor to do stuff you want ( like playing tetris in your calculator) <- Standalone
Both have pros and cons.Cons example: Do you like to restart your Microsoft Windows everyday in your Pentium Processor, when you get "Fatal Error - Illegal operation" blue screen ?![]()
