float_6969 »
https://forums.nicoclub.com/float-6969-u780.html
Wed Oct 27, 2004 10:41 am
This is kind of a hard one. Although I'm not looking for a whole lot more power, I went with standalone (kinda, it's a Power FC). The reason I wanted to do this was because I didn't want to have to keep burning EPROMS everytime I changed something. I knew that the way that the car is built now, isn't nessicarily the way that it will be built in 2 yrs. So for me, it was the idea, that at any point, when I changed something about the car, I could modify the parameters in the computer to get the most from that modification. If you feel that this will be the extent of the modifications to your motor, then I would say to get a simple ECU retune and spend the money on suspension. If you plan on taking it farther later on down the road, then spend the money and get the standalone.
