Beaten to Death, I know...
Tictakman
Came home for fall break and im installing an safc II. no problem doing any of that. Im now trying to set it and im having trouble, i have the settings at sensor 1 and 5, and the throttle at 10% and 50%. any other help would be cool. oh ya, the sensor is hot wire too. the car stumbles at low idle then stalls out sometimes. its very rich.
Zak
:: orion ::
Car: '96 240SX, with KA-T @ 12psi...
What MAF...stock?
Stock is 5/5 IIRC.
Z32 is 2/6...? Somone confirm...
- Brian
Tictakman
ya, sorry it is the stock maf. one thing that is different is that i have all my intercooler piping ran with the maf about a foot away from the tb.
nonchalant rage
Car: s12
uhh, put it before the turbo. that should solve your problems
Structure240sx
::orion:: is correct for the stock maf it is 5in/5out. otherwise you will run very poorly
Tictakman
it seems to run fine after i let it run for a while. its just the initial start up, it will idle high then go low and stumble out or just keep stumbling.
Zak
Silvia007
Car: 93 Nissan 240SX SE Fastback
I 2nd what Nonchalant said.
