I'm glad you took no offense to my mini rant. Long day.
If you are using your car for business, wear may happen in uneven ways and there is no need to chance it.
There was something that jumped out to me in your post.
aft981 wrote:What I also hadn't mentioned was I asked them to look at a small issue I was having around 40mph occasionally - sometimes when cruising around that speed, if I would then try and accelerate a little, the engine would sometimes seem to skip a beat, there would be a slight hesitation, and then it would pull away.
I know the symptom you are speaking of. What you are feeling is the transmission not upshifting until a certain threshold is passed. Basically, part of the transmission shift logic is dedicated for optimal fuel economy, however when in max lockup cycle is commanded (<1/8 throttle application at >42mph). You are only the second person I have heard of with this complaint. Maybe there was a thread about this before but I cannot recall.
I plan on starting a thread about this and I bet if enough people make it known that they have this I can pass this along to the engineers and have a leg to stand on as there are real consumers out there with this exact issue. I wonder if we can get the first NICO Infiniti ECM reflash. Really this issue is a software glitch, and really only occurs in people who tend to drive either in traffic usually at a consistent cruise, unfortunately there is nothing I have found that will fix this and it does not warrant the replacement of any component as it is software related.
AWGD8 wrote:Steve,I bought a 4 year Infiniti maintenance service plan and my oil change is done every 3,700 miles. How do I know if my dealer really change my oil?
The best way to tell if your oil was changed is by opening the hood and looking at the lower left of the engine to look for a new filter, also the dipstick should show clean virgin oil.
AWGD8 wrote:I asked them to use synthetic oil and will just go there every 7.5k miles.You know what I mean?
The companies stand point has always been 3750, although they will not usually alter your warranty for using premium oi and a slightly increased intervall. I cannot in good conscientious get into that any more, as I may not be giving you the correct information.
AWGD8 wrote:The service adviser said he can`t do anything about it. I have to pay the synthetic oil to do it. I wonder how much the cost of 2 oil changed with regular oil compare to one oil change using synthetic? is there a big difference in price? my mileage is at 8.5k miles now and due for 7.5k oil change. That means if I do an oil change at 8.5k miles, I `ll bring it back at 10.5k miles for another oil change to avoid any warranty issue?
That is the position of your specific dealer. Since they are all independently owned and operated they can set the rules (but this is a huge gray area) within a certain cases. In general if you take good care of your EX it will be fine. The engine and transmission in this vehicle are both enhanced versions of time tested models, don't stress it too much. I have many customers who do the bare minimum only when in for a warranty concerns (usually >5k over on their oil change) and they almost never have an issue. Doing slightly more than that will keep your EX happy.
