DAEDALUS »
https://forums.nicoclub.com/daedalus-u128.html
Mon Aug 19, 2002 5:54 pm
So you've confirmed the bad bearing? I haven't done the fronts, but I think I understand the assembly based on the manual. I think the answer to your question is "yes" to both. When you say "huge bolt" I think you mean "huge nut". This nut threads onto the hub end, trapping the bearing on the hub. The nut takes a good amount of torque, so if you don't have a solid bench-mounted vise, then you'll need an impact wrench. Believe it or not, the cheap electric impact wrenches actually work pretty well, and are very useful on the road in case of a flat. Nothing beats air, of course. Other than the nut, everything is press-fit. Note that the grease seal takes up to 1.1 US tons during assembly and that the hub takes up to 3.3 US tons, per the manual. (Yeah, I think a press is needed here.) The hub and grease seal need to be pressed out first. Or hammered, according to the manul (AKA using a "suitable tool"). That one always cracks me up. Hammer to fit, file to finish. Baffle then should come right off, I think. After the hub is removed, remove the spring clip and then press out the bearing. Sockets can sometimes be used as press drifts, but ensure that the inner "points" aren't so big they damage the bearing.. Reassembly is basically the opposite of disassembly.
