karay24O »
https://forums.nicoclub.com/karay24o-u146971.html
Fri Mar 19, 2010 4:50 am
I believe it's a similar problem as the RB's--all the oil gets stuck in the head, and nothing left in the sump. (maybe not nothing, but obviously not enough).
I've been meaning to post pictures, but I chopped up a spare vh head to follow the intersection of oil passages. It's a maze! There's so much flow to the head there's no wonder the block runs out of oil. I guess it's obvious. . . each head has to supply enough oil to lubricate two cams, pressurize 16 hydraulic pivots (double SR20 per head), and supply enough oil for the VTC to work properly
My guess is, if you Modify/convert the hydraulic pivots (lifters) to aftermarket and plug the oil supply to those passages going to all 32 of them, the oiling problem should be kept in check.
The only problem w/ this is, as far as I know, no one makes cams for solid pivots (lifters), and could cause premature wear on those dainty looking roller rockers as the ramp on the hydraulic cams tend to be more aggressive.
Anyone else waste a weekend or two thinking about this problem? lol.
