VegasNow »
https://forums.nicoclub.com/vegasnow-u268441.html
Wed Sep 28, 2016 5:08 pm
Let me just get into it as this will be my first post.
Driving to work and about a mile from work (30 miles driven already) the car just BOGS!! Hard. Push in the clutch, it dies. Let out the clutch, car starts but as soon as I push the accel, bogs again. As i slow into the turn (car currently running kinda) it roars back to life as if nothing happen, hit the accel and it goes for a bit then bogs out again. Clutch in, car dies, restarts with the key but bogs instantlly and never recovers. Towed home.
Fuel pump replaced while car was at work, didnt work. Hence car had to be towed home. Oh this is with over 3/4 a tank of fuel.
Things I've checked
-timing on distributor
- fuel pressure
-spark yes i have it
-every cyc compression 140's all 4
- regapped the plugs to .044 (was at .036)
- cleaned the MAF (brand new but meh did it anyway)
- injector resistance all at 11.0-11.3
- NOID checked injector pulse, nice and strong light
- battery voltage normal, i have an additional pack attached when cranking
- hoses all checked and replaced ones that needed it (replaced the raditator about a month ago due to a leak below the intake)
- vacuum check good, goes with above
- only code i have is for the IACV. and the stupid N/park switch (it a manual, i know)
- replaced coolant temp sensor too
PS. O2 sensor can only be tested correctly if warm, since car wont start, cant do a proper test. Second this wouldn't keep it from starting. And a dirty IACV will not prevent it from starting either.
Hope there is something I'm missing. Please help and thanks!!
VegasNow is online now Report Post Edit/Delete Message
