I was using a Taurus single fan for my SR and that thing blew like katrina, never had issues even in 105F daily driving, stayed at a steady 80 - 85c with a stock SR rad. I'd like to run this fan again. At first I was going to run it as a pusher by cutting the shroud just down to the fan itself and mounting it on the front of the radiator, but the 16inch diameter of the fan is too large to fit in the core support, it needs to be 13.25 inches max. I haven't found any 13 inch fans that'll flow 3500+ cfm so my next option is to mount the radiator inside the core support which will open up a world of fan options to me. I won't have to cut anything this way.
I've read alot of good things about Be Cool from the F-body boards. A few cases where similarly sized griffin radiators weren't cooling as well as the Be Cool's. I am wondering if anyone on here is running a similarly sized rad and/or Be Cool and would like to hear your experience.
This is a koyo rad from an ae86 I might run
