Oh man, all that work put into the engine and only .8 bar?!!? You have to do at least like 15 or 16 psi..what are you using for engine management?nizmo240sx_22 wrote:Right now I'm planning on running .8 bar for a year or so. I'll need to upgrade my bov and then I'll set my goals to around 400 hp and with the manifold, cams , ect I'm hoping I'll be able to hit this with right under 20 psi. I think I could make more but I just don't want to start breaking stuff. I think that'll be plenty for a street daily driver
wait til you get around 10psi and start losing traction flooring it. then 15psi whne you loose traction with half throttle. 20psi is basically impossible to hit on the street. by the time you're spoole dup that high your car is already sideways. if you drive around on drag radials you might be oknizmo240sx_22 wrote:...hit this with right under 20 psi. I think I could make more but I just don't want to start breaking stuff. I think that'll be plenty for a street daily driver
