anotheraznguy »
https://forums.nicoclub.com/anotheraznguy-u2242.html
Wed Sep 10, 2014 12:11 pm
BCM = Body Control Module.
I replaced mine last time. Since the bcm is tied to the ecu which has the key chip info, you can't just swap it out drive to the dealership and have them program it.
Last time mine busted. I bought a used bcm, removed the panels and pretty much had the bcm connected but easily swapped. Then I drove to the dealership, and worked w/ the service department to let me park in front of their garage while i swapped the bcm and they reprogrammed it. It cost i believe 80 dollars.
