Postby
xjaywalker »
https://forums.nicoclub.com/xjaywalker-u123466.htmlMon Aug 29, 2011 9:37 am
Looks sweet.....How did you choose your install setting on the drop? Are you staying with that setting?
I am thinking of going with these on my 06 G35..and always had an issue with being too low for dips, driveways, and speed bumps.. I like the idea of being able to adjust the drop. Is it an easy adjustment ?
Postby
audtatious »
https://forums.nicoclub.com/audtatious-u2438.htmlMon Aug 29, 2011 7:23 pm
I measured with my Tein H-Techs on and decided I wanted the car a bit higher. That led to the initial settings. At this point I want to raise it up about1/4" more after everything has settled down a bit.
They are stiff. Rear pre-load will be changed as soon as time allows and will hopefully take care of it. Thus, impressions I have at the moment are not of the final result.
