bc cams
iHEARTmyCS14
Car: 1997 nissan 240sx
i was thinking of getting stage 2 cam from bc for my kade would this affect me later on when i turbocharge my kade? or would this affect anyother parts on my engine (my engine is bone stock right now) any comment or suggestion??? plz
-g0ku
s14tan
Car: 95 ZenKi SE w/ S14 SR GT28r and bolt ons
I really can't tell ya bro...Free Bump
eazye2000
Car: S13 KA-DET
Shouldn't affect much. There are a lot of guys in the KA-T forum that throw them in when they rebuilt their cars and just run them to break the motors in. Running the car in N/A form is no problem. IIRC, Mass Air Flow metered systems adapt better to cams than a MAP type system, so you should be good to go.So no, it won't effect much. Other than give you more power up top.
iHEARTmyCS14
okay thx guys now im just waiting for the parts to come in
-g0ku
s14tan
whats the gain on them anyways?
the converted
Car: '99 BMW M3 6.0
'88 Toyota Celica All-Trac (somewhere in Cali)
'20 Toyota Tacoma
Actually once you go turbo you'll probably make a little more power with the stock cams than with the BC's. NA cams make more power with more lift and duration, cams for turbos however tend to have a smaller duration to them.
iHEARTmyCS14
im not really 100% sure but i believed it give u more power at the high end and i a meanner idle sounds hehe
-g0ku
eazye2000
Car: S13 KA-DET
the converted wrote:Actually once you go turbo you'll probably make a little more power with the stock cams than with the BC's. NA cams make more power with more lift and duration, cams for turbos however tend to have a smaller duration to them.
Not too sure that BC makes a specific cam for N/A, or Turbo. They just have 'Stages'.
Here's some N/A, and Turbo cams from PDM. Check the specs. http://www.pdm-racing.com/products/cam_corner.html
And here's some from BChttp://www.briancrower.com/mak...shtml
Hope this helps. Read up a little on them and make your own decision. And listen to the people who 'have' them, or 'have had' them. Maybe check some dyno sheets that some of the guys have posted up. I know the KA-T guys love the BC cams after they've gone turbo.
*On a side note, my car is a KA-DE Turbo and it falls on it's face after about 5500-6k or so.
Kaforlife
Car: 1992 240sx
Which cam are you running eazye2000
turbo2nr
Car: 97 240sx (kouki)
ka-t usually gain a fair amout from cams and widing the power band. with stock cams the ka will stop making power after 5500rpms, the engine cant flow enough air, the valve lift and duration are too short for all the air comming in .. the 264 help them stay open longer helping you to keep making power untill redline..
look at any ka dyno with stock cams around 5400-5600 they dont make more power it slowlys decrease..
when i have enough cash im going with 272 and re doing the valve terrain.. hopefully gona rev it till 7500...
for na you should see good gains.. i cant rember but i was reaing some where of a 200whp n/a ka and it was using the 264's with a built valve terrian..
celica3sgte94
Car: 99 g20 89 240sx hb with 95ka24de
i just placed an order on the BC stage 2 cams too ill give you guys an update when i finish installing it
Florida240sx
I love them. Awesome pull to redline. Made me jump off the rev limiter because it pulled so hard. Next week I start my engine rebuild again* and should have her running soon.
Brandon93240
Car: 1993 240sx
I installed them in my s14 after I had the stock ones in while turbo. It was a noticable difference in power on the dyno from about 3200 to redline. A set of stage 2's, cold air, header and ebay exhuast would be decent mods for a dd.
DevilMB3017
I ran them N/A for a while before I pieced the turbo kit together. You can advance the timing a bit with them and get a nice loopy idle - sounds mean as anything with exhaust. They definately pulled harder, and I didn't feel a power decrease till 6.5K RPM or so. Definately a nice addition.
With turbo, my ECU is tuned for them, so I don't get a loopy idle any more, but it definately pulls hard till redline/shift points.
wishihadas14
Car: '93 240sx Coupe
I'm about to be done with my rebuild, but it'll be a while before I have the money to build a turbo kit for it. I will be sporting the setup described by Brandon93240 above, and am curious what kind of gains this will give me in the meantime. Also, DevilMB3017: How much did you advance your timing with the 264's? A tooth or just sliding the dizzy?
eazye2000
Car: S13 KA-DET
Kaforlife wrote:Which cam are you running eazye2000
I'm running the stock cams that came in my '93 S13 KA-DE. I only did a mild port and polish job. Really just a gasket match, and smoothing...
DevilMB3017
Just slide the dizzy a bit. A small bump, worked wonders for idle though. Acutally at the reccomendtion of my engine builder.
