BC cams and synthetic oils????
cattrikk
Car: 1989 Nissan 240SX Coupe
ok, so i always fun royal purple in the SR, but one of the info guys at brian crower says not to run synthetics, only petroleum based oils...you guys have any opinions or experience on this??
thanks
Doya
Car: '95 240sx KA-T
Did they say don't use synthetic at all or just not with their cams.
compactfean
Car: 89 240sx s13 sr gt3071r 23psi
B14 sentra ser sr20de-t 7psi
daily
That makes absolutely no sence. I'd stick w/ the purple! I was the store mgr for jiffylube for 5 years and from all the classes ive taken from numerous vendors, have learned that the only engines that you can't use synthetic is rx7 and rx8. I would go into details but my explanation would be quite lengthy. Just stick with the purple!
cattrikk
i told the guy, i wanted to know if any break-in time was needed. he said no. and then said, remember, use petroleum based oils- no synthetics...which is all the SR has had...i dont see why using a better oil would be bad for the BC cams....does anyone else run purple and BC camS?
Doya
Car: '95 240sx KA-T
I used to have BC Cams in my s13, but I never did use synthetics.
compactfean
daily
Dunno I got tomei cams. I don't think that sr knew what he was talking about. The only reason ive ever heard not to use synthetic is with a rotory because its squarts oil in the comb. Chamber and sun. Is too slippery and engine gets more blowby and looses power. That's per manufacturer! I'd call and talk to someone different. The only thing I can think of is if there is an additive that would somehow react with the metal...highly unlikely.
motoxris
Car: 92 240sx coupe
If you started running synthetic, you risk engine failure if switching back to petroleum.
liquid_cool
Car: 1990 Nissan 240SX KA24DE-T swap 8.6:1cr, duelsprings, ti retainers,supertech pistons, K1 H-beems balanced internals ect ect
where do they get all this info from....its bs man...ive run the BC stage 3 cams 272's for well over 2 years with royal...there is no side effect what so ever...and switching back to normal oil...ive never ever seen or witnessed an engine failure due to oil..wtf....these are urban legends that still float around..the crap slung on forums these days.
rioredstang
Car: 1993 240sx SCCA ITS
Amen to that liquid_cool. I don't know why he would say no to syn. oil. I have heard that some cam companies want certain oils for break in. I think comp cams even sell their on break in oil. After the break in period then switch to syn oil. I think the oil companies have removed some of the sulfur in the oil base stock that helped break in.
cattrikk
well thanks guys. appreciate the help.
