The braking distance between stock and upgraded brake systems will always have an equal starting point. The difference will come with speed. The better a brake is able to dissipate heat, the less brake fade. They will all stop in the same distance at 30 mph, but at 60, the difference grows, at 80 the difference get larger and so on. So in a initial panic brake situation at normal freeway speeds, there would be little difference between stock and the other kits. But if you are blasting down a canyon road, those of you with bbk's are still having a good time at the bottom of the hill. those of you with stock brakes are not. Because of the ap racing ability to dissipate heat quickly, I think that they would be superior to the akebonos in aggressive driving.
SEismyG wrote:Little curious on this...can I use the 13in G37 rotors with Altima coupe pads? Or do I have to use G37 pads?
altima brakes are 11.7 in diameter, g37 are 13in, g37 with sport package are 14in fronts. Cannot mix and match components. What ever rotor you use, you need the matching caliper and pads with it.
