bbk spacers on 20's
sda206
Car: 07 m45
Look what arrived! Now i have to install :crazy:
Does anyone know if I will need spacers running, Concept One RS-55
Front: 20 x 8.5 +30
Rear: 20 x 10 +42
Thanks in advance!
Quis
Car: 2006 M35x
sda206 wrote:Look what arrived! Now i have to install :crazy:
Front: 20 x 8.5 +30
Rear: 20 x 10 +42
Thanks in advance!
I think you're going to, but I'm not 100% sure. I just install my bbk last week, and had to use spacers on the front and back.
My wheels are the the Vertini Hennessy, and these are the spec
Front 20x8.5 +35
Back 20x10 +45
Had to use Ichiba v1 15mm spacer for the front, and 10mm in the back. which made the front +20, and back +35
My wheel design is very close to yours, only with more spokes.
sda206
Car: 07 m45
Alright, thanks, I 'd hate to start with out em!
mexillis
Car: M45s
this is what you need to do: http://www.370zcoupe.com/tech-images/ak ... mplate.pdf & http://www.conceptzperformance.com/imag ... mplate.pdf
and it looks like this http://www.370zcoupe.com/tech-images/ak ... mplate.jpg if the template hit's your spokes when rotating add spacers until it clears. I did this by purchasing some cheap ones at auto zone and then returned them after I got what I needed and purchased the spacer(s) necessary to clear ie 20mm, etc
sda206
Car: 07 m45
Thanks Mex, these will be helpful. You would think that since i ordered the kit from them, they would have told me of this template..Thanks again
