raw0330 »
https://forums.nicoclub.com/raw0330-u9768.html
Thu Jan 21, 2010 3:07 am
I've been running the SPL version for a few years now on my summer dd, with NO problems whatsoever. The primary reason they state fro off-road use is because if something happens to affect them, it tends to be catastrophic. They generally don't bend like the factory sheet metal, they shatter. I can't speak on the BV ones, but the SPL's haven't loosened up or mis-adjusted on me yet. Your heim joints on the BV's are not sealed, so they do need constant attention as far as cleaning and lubrication. after driving in the rain or wet, dry them out EVERY TIME and re-lube them or they'll rot up quickly! Don't forget to have these installed, or at least set up at a RACE alignment facility, due to the fact they will change your roll center, and other alignment settings and can greatly affect the handling of the car--good or bad.
