i-Zer0 »
https://forums.nicoclub.com/i-zer0-u31987.html
Sat Nov 12, 2005 4:37 am
Let me just clarify: My idea is that this one band, as you have stated, is slipping against the wall of the body that houses the gears. My theory is that it needs to be adjusted to put a little more pressure against the wall, thus eliminating more of this slippage. Currently, a few more rpm's are given when the D position is selected, the band is not fully engaging. There is enough 'grip' or engagement to engage part of the planetary gears but not quite enough for it to happen instantaneously. Once enough momentum is created from the more rapid rotation, more 'grip' is created and the car moves forward in a very soft manner. As I mentioned before, the car shifts fine otherwise. This was the only issue.
