juls213 »
https://forums.nicoclub.com/juls213-u19716.html
Thu Mar 01, 2007 7:33 pm
Hey buddy this is what u do, get a multimeter and check if u have 12v when car is shutt off then see if you have 14v when car is turned on. If u have 14v when car is on this means the alternator is working. Next u want to check for a draw on the battery, 1st disconnect the negative terminal and hook up a test light to it so one side of the test light goes to the disconnected negative terminal wire and the other side of the test light goes to the negative terminal battery. You will see if you turn on your lights the light will turn on that means the circuit is closed and operating. You can see what thing is on all the time and ultimately draining your battery by disconnecting fuses one by one. Good luckINFINITI TECH
