battery wont hold a charge...
nissan~240sx
Car: 1993 Nissan 240sx SR Blacktop...Finally Boosting
the battery is nudged in between my cold pipe and my fender. so its very small but i really dont think thats the reason why its not keepin a charge. basically what happens is, we have to charge the battery everytime we start the car after it sits for awhile. after we run it for awhile it starts after each time because the alternator charges it. but then after it sits overnight, the battery is dead. im worried its a ground wire but my dad who is a mechanic says its just because the battery is too small. any thoughts
RedlineBoost
Car: 2004 Mazda RX8 GT, 89 240sx sr20 swap, 74 Nova Built 383, Chamelon Iroc
Dude.. My tractor has more cold cranking amps then that.. No offense. If you cant find a bigger CCA Battery to fit in there, Think about relocation. If it continues to go dead, Check for a wire grounding out or current draw.
the converted
Car: '99 BMW M3 6.0
'88 Toyota Celica All-Trac (somewhere in Cali)
'20 Toyota Tacoma
Get a meter on there and see how many amps your car is using when it is off. It is possible that something is pulling more power than it should or is wired wrong.
nissan~240sx
do you think it's best to buy a relocation kit they sell online or to buy a bunch of wire from a hardware store and do it? personally i have no idea how to install one and i HATE batteries and electricity with a burning passion becuase i have seen soem crazy stuff happen with them...
the converted
Car: '99 BMW M3 6.0
'20 Toyota Tacoma
Who did the stereo install? Did this problem start around the same time? Having a bigger battery won't fix the problem, just make it so it takes a little longer before it won't start again.
ZOMG.SR20
Car: 1990 s13
where are you located?
nissan~240sx
ZOMG.SR20 wrote:where are you located?
braintree and amherst. why?
ZOMG.SR20
Car: 1990 s13
i saw MA and was like OMG Masshole
240life
Car: 1993 Nissan 240SX S13 Coupe SR20DET blacktop
That battery is seriously under-powered and I am betting your father is right...Summit sells a nice easy install kit for relocation for under $80
the converted
Car: '99 BMW M3 6.0
'20 Toyota Tacoma
If it wasn't starting the car at all I would agree with you that the battery was too small but it work just fine unless the car sits over night, that says it's a power drain issue. You'll have to get an ammeter on it and start disconnecting things until you see power draw drop and then troubleshoot whatever circuit was pulling the power.
nissan~240sx
yea im going to do that asap! hopefully theres no draw of current....
B00STFED
I t could be a bad battery or a bad alternator
