Battery won't charge.
240sxFTW
Car: 89, 240sx coupe
Ok so I have an issue. I got off work today, went to start my car and there was nothing, no lights, nothing. So i figured i mustve left a light on or something. So i boost it, get home, turn it off and it wont start again, same thing, no lights. So i was thinking "im a dumbass i shouldve left it idle forawhile to let the battery charge."
So we boost it again, let it idle for a bit then realize that theres almost no gas, so i was about to leave to get gas then it quit on me at the end of the driveway. So we boost it AGAIN. pull it into the garage and now im charging the battery with this motomaster thing. Does anyone know what my problem is? we filled it with a little gas when it was running. Could it be my alternators shot? Its got 135000 kms, 90 000 miles? So yes its charging for the night but im gonna need to have it runnin for tomorrow. Anybody have a diagnoses?
240sxFTW
PLEASE OH PLEASE. i wont sleep tonight if i dont know the issue. bump
Amtk240
Car: 1997 Nissan 240sx SE Red S14, and 1995 Nissan Navan 240sx Ruby Pearl S14.
So let me get this straight.... You didn't have any battery power and then you charged it. It charged up alright but keeps going dead? Is that right?
240sxFTW
Basically yes. Alternator?
slow s13
Car: cars, photo, music
yeah just find someone with a volt meter or go buy a 5 dollar one at harbor frieght get car running and put it on the battery and if its not damn close to 14.4 volts your alternator is dead
see your in canada probly no harbor junk up there its cheap tool outlet store.
lilpiton
Car: 92 hatch
or just start the car let it idle and unhook the battery if it dies its your alternator.
Amtk240
I'm leaning toward the Alternator being bad. Good advice about the voltmeter check.
History: Back around the year 2004 I left from the house and got about two miles down the road to the red light and my entire car just went dead. I immediately hit the Hazard switch, but the car was literally dead. Absolutely nothing on the car worked, nothing! I was freaked out to say the least. It stayed dead for about a minute and then it just powered up again. Of course I had to start it up again, but all the electrical stuff came back up like the radio, clock, headlights, dash lights, etc. Weird, huh? I never did figure out what happened? Maybe the ECU reset itself?
240sxFTW
Ok i started it up. It started fine after i took the charger off. Unhooked the battery on both positive and negative and it still ran. So I dont have an alternator problem. Maybe a s***ty batteryÉ
240sxFTW
Amtk240 wrote:I'm leaning toward the Alternator being bad. Good advice about the voltmeter check.
Thats a weird story. I have a similiar one. I unhooked my sub and didnt wrap the wire in electrical tape, took it around the block and it died on me. diagnosed it with a buddy, blown fuse from the sub wireing. scared the crap out of me but only cost me about 3 dollars to fix.
Fibre guy
Car: 91' s13 RB25DET, 95' s14 bone stock, 87' Wrangler 4.6L stroker
Sounds like maybe a bad ground? If you can move the cable with your hand it needs to be tighter.I also see some corrosion on the battery terminals try cleaning them up with a wire brush and stick them back on.Could also be a bad battery could be time to replace....Alternator test "lilpiton" suggested does work too.Good luck with the problem.
Amtk240
Are your battery terminals clean and tight? If you replace your battery I would go with an Interstate Battery or a Premium Die Hard from Sears, IMO. They both have been great for me.
240sxFTW
my battery terminals are far from clean. the positive terminal has white s*** all over it. the negative is a little bit rusty.
TwoFoutyEsEx
Car: 1997 240sex LE
If your car died while driving the your problem is your alternator
Amtk240
Use a wire brush to clean them up. I would take the positive and negative lines off of the terminals and clean them up really good making them as silver in color as you can and then hook it all back up tight until you can get a new battery and/or terminal clamps.
240sxFTW
thank you guys so much. Ill have her fixed up in a jiffy
DruidAT
Car: 98 240sx
I had a similar problem. Turned out to be my battery terminal clamps... They were clean on the outside, rusty on the inner part where the clamps makes contact with the battery terminal. I sanded them down and it fixed the problem. I spent a whole day trying to figure this out and I even went out to buy a new alternator and started because the car stopped cranking after a while. Hope this helps you.
ThuG LyFe
Car: 95 S14
hope it's just a simple alternator or battery problem.
but i really think it's from the horrendous wheels that's causing the problem.
AZ89two4Tsx
Make sure your cables are in good condition and TIGHT on the terminals. There's also some "lube" if you will that'll keep your battery from corroding.
It just sounds like you have a dead battery. No biggie.
SeVa-S13
Car: '05 GTO 6spd
Titles:1. Should have something to do with the thread.2. Should never be in all caps.Thanks.
240sxFTW
SeVa-S13 wrote:Titles:1. Should have something to do with the thread.2. Should never be in all caps.Thanks.
Ok sorry about that. So ya today i will clean my battery terminals then I might go out and buy a new battery some time soon. Is there any signs that should tell me that i need a new battery. like an expiry date haha. I dont know i just dont want to go out and buy a new battery if i dont have to. I have to put my money into other things on the car right now
Fibre guy
Everyone basically said what was in the first few posts.... Auto parts stores around here check your battery for FREE. Check if any parts stores around you do the same thing.They also check the alternator for free.
AZ89two4Tsx
Yeah, if you're car doesn't start!
bware113
Car: '02 BMW TS M3
1990 Piggy Hatch
I just had the same issue...My car mysteriously stopped working and I thought I left the dome light on or something. Jumped it and drove a while and it was doing the same. The battery read that it had 12 or volts available it had a low charge. Come to find out the battery was just not accepting a charge after taking it to Adv. Auto Parts. Bought a new battery and now Im A.O.K.
P.S.-this was all like last week
Ghast
Car: 1993 240sx, 2002 Lancer ES, 2006 350z Enthusiast
U got enough water in the battery?
So the protons and neutrons can do their thing?
180sxblack
Car: 180sx
sherwood park ehh?havent ran into many albertans on here yet.im an okotoks local.
240sxFTW
bware113 wrote:I just had the same issue...My car mysteriously stopped working and I thought I left the dome light on or something. Jumped it and drove a while and it was doing the same. The battery read that it had 12 or volts available it had a low charge. Come to find out the battery was just not accepting a charge after taking it to Adv. Auto Parts. Bought a new battery and now Im A.O.K.
Sorry for the late post i havnt been on nico in awhile and checked my posts. Thats weird that we had basically the sajme problem so ya i bought a new battery and ive been fine ever since.
Ghast wrote:U got enough water in the battery?
I feel unsafe opening up my battery... and i dont know jack about protons and neutrons. But new battery so im all good. thank you though.
180sxblack wrote:sherwood park ehh?havent ran into many albertans on here yet.im an okotoks local.
Yeah sherwood park. How far is okotoks from edmonton? you should come out to the united cycle meet on may 1st, its gonna be huge.
JSDEVILDOG29
Car: 1997 240sx, 1986 300zx turbo,
Ive used optimas for years. IMO they are the best. No maintenance and they stand behind their product. Ive never had a problem with them. I even bought a used one and they warrantied it and gave me a new one.
