rjdmmfl1 »
https://forums.nicoclub.com/rjdmmfl1-u77059.html
Mon Oct 27, 2008 7:16 am
do it in stages... try to spend the least amount of money to achieve what you want.. your L7's draw a lot of power to run..... 1st, I say do a 0-gauge Big 3 upgrade.2nd, I say replace your factoryt battery with a Kinetik HC1800 battery... all of the new optimas are recylced, some folks have been having problems with the new optimas' power cells failing, but some haven't.. its kind of hit or miss with optimas... most folks nowadays swear by Kinetik!
3rd, add another power cell in your trunk. This can be a second battery or something like a BATCAP or a smaller Kinetik power cell. I'm running a Kinetik hc1800 for the factory replacement and two Kinetik HC600's in the trunk!
Last, you have a 2.5, so your alternator is only 110 amps... you can either get your alternator rewound (to something like 150), or you can buy a high output alternator. The second option is usually more expensive and in my opinion should only be done if all else fails.
**EDIT** sorry for all the typos earlier, I rarely check my spelling when typing on this forum... I've corrected most of em now!
Modified by rjdmmfl1 at 5:33 PM 10/27/2008
