battery troubles
el5y
Car: 93 240sx
I have a 1993 hatch, I just replaced the batter in march of this year, and now it seems the battery is dying, again. when I start the car it has trouble turning over, like its just not getting enough juice. the only thing I've changed since that time is the interior, door speakers, and my head unit. any ideas on what it could be? alternator not charging the battery or something?thanksEric
IveBeenBad
Car: 1990 Nissan 240SX Fastback STOCK BIOTCH
make sure your battery connections are tight
allthrottlenobottle
Car: 91 s13
try putting a voltmeter on it to see if your alt is charging.of course check all connections including grounds and if it is not a maintenance free batt. check the level of fluid in the batt.
el5y
Car: 93 240sx
Alright well after the first post my car began running fine, but for the past few days it's been getting weaker and weaker again and now it won't start. Any ideas now? my connections seemed fine when I changed the oil last week. so I don't know whats going on. It started dying after I turned my stereo up really high, I don't think a 250w system would drain the battery that much...
Eric
C1rca
do a battery leakage test with a volt-meter by putting one wire to one post and put on in the middle of the battery and if you get any readings clean the top of the battery really good
el5y
Car: 93 240sx
I tested the battery, its fine, now I think the starter may be dead, does anyone know exactly where it is located so I can try to smacking thing?
Eric
C1rca
lol... go to http://www.zeroyon.com it has a service manual for s13s and i think s14s it should help
el5y
Car: 93 240sx
Thanks, starter has been changed, and it starts perfectly now. pretty easy change as well, too bad I didn't have the time to wait and just take mine apart and fix it that way.
Eric
