S13xCrazy »
https://forums.nicoclub.com/s13xcrazy-u48564.html
Thu Nov 01, 2007 12:47 pm
haha!
First i thought waterpump...replaced that and it still overheated...but the water pump was DEFIANTLY shot, the seal was all ****ed up inside.
then i went ahead and compression tested it.97 105 102 100 (around there)
Tore the head off, and the exhaust chambers were just straight up WHITE. replaced the gasket, put it all back together. Compression jumped to 150ish
still overheated.took the head off again, measured it, and it was FOUR TIMES the maximum limit of 'warpage' aloud.
Slapped on another head i had lying around, and now shes 176 across all four and runs beautiful
ball joint was shot though, just replaced that and balanced the tires today.
