BATTERY
fsbaksh82
Car: 2001 Infiniti I30
Hey
My car wouldn't start. :facepalm: I had to get it jump started and it started afterwards. I was parked and had the cd playing and the emergency lights blinking for about 30 minutes, engine was off. Did the emergency lights and cd player kill the battery? :confused: Is this a sign that the battery needs to be replaced? I bought the car with 135000 miles with that battery. Its been two years and now up to 160000 miles. I replaced the alternator and starter about 1.5 years ago. There were no warning lights (battery and brake light). Any input will be greatly appreciated. :)
Ziggy1621
Car: '90 Z32 TT (Shibui)
'90 Z32 2+0 NA
'68 311 Roadster
2004 Rx330
2011 BMW 550i (TT)
Shouldn't kill it that quickly. If you replaced the alternator a couple years ago cause it was bad, it definitely could have let the battery run down too low a few times. Probably wouldn't hurt to replace it.
NutriaforBreakfast
Car: Nissan Maxima 1995 VQDE engine
You should use a multimeter to check the output of the alternator
Make sure your alternator belt is tight too
loystock
Car: 10 Honda Pilot
97 Infiniti Q45
03 Infiniti Q45
97 Infiniti I30
06 Infiniti M35 Sports
04 G35 & 99 I30-RIP
Lead-acid batteries last for 3 years or more, depending on location and usage. A fully charged battery must read 12.6VDC or higher. A battery with 12VDC or lower is basically 'dead' and useless. With engine running, the alternator charging voltage should be greater than 13.8 VDC (spec is 14.1-14.7 VDC). Check/clean your battery connectors as well as the battery and alternator cables/wiring for corrosion, short circuit, etc.
