captainclutchkick »
https://forums.nicoclub.com/captainclutchkick-u41175.html
Fri Jan 26, 2007 7:42 pm
i have a 90 240sx with a 97 rb25det from a nissan skyline and im using a smaller 12v battery since space is limited, my car has sat for a few weeks and the battery went dead in the cold, i charged it to 11.5 volts and put it back in and the car would not start, so i jumped it. on the gauge it said the battery was at 14.4 volts while the car was running so i drove it around the block, if i reved the car over about 4000 rpm the battery would drop down under 10 volts and the car would almost die until i let off the gas and the voltage went back up. is my battery bad and will not hold a charge?
