Battery reversed- Repairing the damage
crobertson
Car: G35 Sedan
I bought My G35 off a friend that someone connected the battery backwards. I've been reading a lot of threads and forums. I'm making this summary page to help others while I figure out what is going on. The car drives fine now, but I have a few issues left
Here is what I have done so far;
  • Replaced alternator
    Replaced Stereo fuse
Here are the remaining problems.
  • Stereo -no power
    Heater runs, cant change fan speed and none of the buttons work. Set on 75 Auto
    Speedometer doesn't work
    ABS light on
    VDC light on
    Service engine soon light
Here are the codes;
  • P0500
    P1212 (Power-train ABS communication)
    P1574 (Power-train)
    U1001 (network)
Here is what I plan to do;
  • Replace ABS control module - Should fix ABS, VDC and speedometer
    Replace climate temp amplifier - Should fix the AC controls
    Remove/inspect stereo. Replace with factory if damaged.
If you have recommendations, Please post them.
telcoman
Some friend!
Take it to an Infiniti dealer to have it thoroughly checked out and send the bill to your friend.
Telcoman
akafred
Car: g35
did you get this sorted? i have one with the exact same problem. what all did you have to replace?
