lou from ny »
https://forums.nicoclub.com/lou-from-ny-u133029.html
Sat Apr 08, 2023 11:07 am
hi all, thanks in advance for any help. i tried searching and didn't find anything...
i have a '15 rogue that doesn't get driven much. i bought a battery in dec. 20 from the parts counter which was found to be defective and replaced 4-22-21. fast forward to today. battery won't accept a trickle charge, nissan says it is indeed bad not getting past 425 CCA on their equipment. they say the original dec date is the date they use, not april. if it was april, they MIGHT be able to do something...they are calling corporate to see policy Monday, but think that the 84 month pro-rated warranty is only if they install the battery. since i did it, i only get 2 years. this just doesn't sound right on a few levels. why buy a better battery? i bought top of the line to avoid this exact issue.
am i wrong? should they pro-rate? should i get a new replacement battery no charge? it's just under 2 years since i got this new one.
thanks!
