mmartin110 »
https://forums.nicoclub.com/mmartin110-u178024.html
Fri Jan 20, 2012 2:39 pm
This is not a easy process on a Infiniti Mx5..There are plastic panels you need to remove..when working on the M remember engineers like plastic!!!
Remove 4 covers to remove and replace the battery:
1. Cover over the windshield washer reservoir (I leave these off anyways)
2. Cover that says BATTERY on it
3. Cover that holds the battery cover
4. Cover over the bottom edge of the windshield on passenger side (trick here)
That last part is a little deceptive, because it looks like the windshield ledge over would require the removal of the wiper arms. This is not true. The cover is actually divided into two pieces. You only need to remove the rubber gasket from the top edge, then unclip the passenger side from the rest. Look at the middle there is a clip at bottom edge and you see small line separating them. Pull left piece towards front and it will snap out. That snap is all that holds it.
Now finally you can remove the battery like a normal car.. The infiniti engineers are not normal..;-)
