Hey guys, I'm running my own remote battery kit. I have a completely sealed gel cell or what not batteries I will be putting in the trunk.
From what I've read, people have usually clamped, welded, or put a terminal block for the wiring.
Here's what I'm thinking:
Using 0 gauge wire from battery in trunk to engine bay Connect 0 gauge to distribution block input Connect starter/alternator/all the other things normally connected to it to the outputs
The gauge wiring kit:
http://cgi.ebay.com/ws/eBayISA...&rd=1 - ebay item 5749005647 - Lanzar audio 0 gauge kit - 17' power cable, 3' ground cable.
The distribution block:
http://cgi.ebay.com/ebaymotors...38636 Stinger fused distribution block, 0/4 gauge in, 4/8 gauge out
I'm hoping to do this since it "seems" a little safer than just clamping the battery cables together and doesn't require any welding/torching.
The box will be an aluminum billet one that was made to hold the optima battery.
Another reason for trying to use 0 gauge is that I already have that hooked up to the secondary battery in the engine bay - since I"m moving both to the back, I can reuse that cable and just get a couple short 0 gauge for the back and just use another distribution block to connect things around the engine bay. (I haven't taken the car apart to see how all that stuff is wired tho - something I will be doing later on this month or next).
Are my gauge sizes ok? choice in block ok? Any recommendations?
