onosqv »
https://forums.nicoclub.com/onosqv-u507.html
Fri Oct 03, 2008 12:29 pm
I understand you want to run it passenger side, but supercharger/cold air/etc don't necessarily need to be done on that side (I didn't read that you want to move the intake to the passenger side, just that you wanted an electric supercharger - usually people lose a lot of credibility when they mention anything like that ).
I don't have any questions (I've done my own write up on battery relocation a while back), but typically, when posting diy's, people put the pics on here as courtesy (makes it so you don't have to visit another site just to see a write up). Also sort of helps build the repository the mods have been setting up (look @ tech articles).
Again, I'm sure you'll personally be fine w/ mounting the terminal there - even w/ your circuit breaker near the battery, just think about it: the short in front where terminal is gets to build up all the way (8-10 feet's worth) to the circuit breaker before it is stopped. It can get dangerous pretty fast - just pointing that out as a personal thing (and typically in battery relocation writeups, that's mentioned - people usually put a circuit breaker on both sides).
