Soulja »
https://forums.nicoclub.com/soulja-u11149.html
Tue Oct 26, 2004 10:25 pm
I used welding cable, and a marine battery box, $4 at walmart. I ran the + wire up and to the terminal on the starter solenoid with a ring terminal, and just extended the 2 wires that go to the underhood fusebox, and also ran them to the starter solenoid. It is a much cleaner setup than what you got going on there. I also ran a ground cable from the trunk to the engine compartment, to the stock ground on the intake manifold, and then a cable to the ign coil, distributor, and alternator. I did also ground the battery in the trunk. I used a marine terminal on the negative post of the battery, so I can just unscrew a big wingnut and disconnect the grounds. As of right now, I'm just running the standard battery, but I'm going to pick up an optima eventually. I actually have one in my garage, but I'm too lazy to test it and see if it will hold a charge.
I also have a full interior in the rear, I just cut the carpet and the padding around where the battery box is.
