Battery Relocation?
UltimaKa24
Car: 1999 nissan altima se
obx 4-1 header
intake
p&p head
soon to come
BC stage 3 cams
BC full valvetrain
BC 2.6l stroker
AEM EMS
Stillen 4-1 header
DIY intake manifold
not sure if this would be the right section, if it isn't, my apologizes. but i was wondering, with the 1999 altima, how there is two main power cables running to the positive terminal, can i just splice them into one and run one solid wire, of do i need to run 2 separates? thanks
BzOaY
Car: 2008 Altima Coupe
Not 100% sure but they might not always be pulling the same power or not constantly pulling power, one could be your starter and the other to power everything else...? correct me if i am wrong here
UltimaKa24
obx 4-1 header
intake
p&p head
soon to come
BC stage 3 cams
BC full valvetrain
BC 2.6l stroker
AEM EMS
Stillen 4-1 header
DIY intake manifold
actually i do think you're right because i followed it to the starter. i have it separated with a 2-1 connector which the 1 side attaches to the terminal. what if i keep theim on the 2-1 and bolt 1 extension wire to that?
BzOaY
That should work as long as the starter wire and the other power wire are still separate they will pull power when needed? if i understood you correctly
