Battery Relocation?????
treborzaid
is it nessecary to relocate the battery to the trunk when i install my FMIC or can i just get a smaller battery?
180fan
Car: 89 fastback
searching could have yielded results on this. you can use a small battery like a genesis or put the battery in the back.
VeloceDrift
Car: 1993 Nissan 240SX S13 coupe
1995 Nissan KA24DET
treborzaid wrote:is it nessecary to relocate the battery to the trunk when i install my FMIC or can i just get a smaller battery?
their is also some FMICs that have the inlet and the outlet on the left side letting you run the piping over the fan shroud like the OEM intake.
brandonb012
Car: 91 240sx
get a miata battery or relocate!!
slowsr20
Car: 95 240 sr20det
i would just put it in the back. it looks alot cleaner to. and saves some space up front if u need to work on the motor etc etc.
S13FASTBACKSR
Car: '92 Fastback SR powered
i would get a smaller battery AND put it in the back..because like stated above me it looks cleaner having it in the back but with a smaller batter you shed a little bit of weight..but if you put it in the back please make sure you fasten the box down where it will not tip over allowing the battery acid to pour out and eat up your trunk interior
nissanman04
Car: '90 240SX, '95 Subaru Legacy
gonna put mine in the back since my battery tray is too rusted to bolt the battery down.
180fan
Car: 89 fastback
^^ I was in the same boat. Rusted tray and fmic so cut out the rusted tray and moved a normal optima redtop battery to the trunk.
